Lows + Weight. Gonna happen?
Right,
Early in the new year I plan to get rid of my 6n2, and buy a MK3. I've been surfing through the build threads etc and I see a lot of people talking about how their wheels rub the arches when there's people in the back.
I'm in a band, and I very often have 4 people (including me), 2, maybe 3 guitar amps (one very big), 3 guitars and a heavy cymbal bag in my standard 6n2. Obviously no rubbing problems there as it's 4x4 height to start with!
So am I going to be able to get it sitting low, with wide-ish wheels, and still carry all that shit in the back? I've never planned to have it silly low, but obviously I want it to look good, and be practical.
Help?
Cheers,
Fisher..
  • Replies 15
  • Views 1.5k
With all that weight in there I would expect It to rub, would you not be better of getting something like a estate if you have to carry load of band equipment?
it depends on the wheel/tire spec, stiffness of the shocks and amount of drop you go for. there are far too many factors to consider before saying they will or won't scrub.
my polo was running 13x7, not sure of the offset without going up to the lock up but it was low enough to give a bit of dish, with 10mm spacer iirc, the tires were quite chunky but did have a bit of stretch on them and the only arch work it had was the lips rolled back
there was no rubbing on the back even when it was as low as a mk3 will go on the rear (sitting on the axle). it's all about getting the wheels and tire specs just right tbh.
Edited by McLOVIN
Cheers McLovin, I wont be dropping anywhere near that much! I'll probably go for 60/40. So I'll just do a bit of research on the tire size. Ideally I would like some ATS Cups or some banded steels. I don't know anything about tire measurements so I'll have to do a bit of reading.
Rustproof, I'm only 17 (18 by the time I get the MK3) so I don't think I could insure an estate. But tbh I've got my heart set on a MK3 coupe. And I personally don't like the look of breadies.
I think I'll just have to compromise on what wheels fit under the arches. I plan to buy one off here that has already been lowered and stoof, so the money I have left over will go on some suitable wheels.
As long as I know it's not going to be impossible, my mind will be at ease.
Cheers lads.
Wide wheels will be a no-no.
But if you can get some to tuck... and possibly give the arches a cheeky roll, you should be fine.
But, being low and having that weight in your car, wheels rubbing will be the last of your problems
One good way is to put some rubber spring assisters in the rear springs,caravan lovers use them. Or you could probably find some higher rate springs the right diameter from the likes of Rally Design,taking them to your required length with the tapered coil cut from each end so they seat in the Polo cups,but this second option would give you a harsher ride than the towing assisters,particularly unladen.
I've fitted a beefy rear anti roll bar from a Rover 220t,stops the rear from squatting even with people in the back.
But it depends how far you wanna take things - common sense says that wide wheels plus slammage plus five people,plus heavy sound equipment.. it isn't gonna compute well.
You're all a good 400kgs,if not more,when the car's not even double that. Such a percentage increase over kerbweight is a lot to ask of any car,let alone a lowered one.
estate clicky with the money you get from the 6n2 you could afford this with a few quid to spare
mk1 golf? rear coilovers have higher spring rate so would be a good option plus you can get the ride height perfect for enough lows but no serious rubbing
Use caravan spring assisters or stack up bumpstops to limit the suspension travel. Your ride quality's going to be shite, but you can stop it scrubbing.
If you cut stock bumpstops down their length then you can clip and unclip them from the strut as and when you need them - and cable tie them in place when in use. Pikey, but it works.
I've used the spring assisters myself, they're more expensive than bumpstops but very easily fitted. They're the less pikey option, in that they alter (stiffen) your spring rate, rather than just limiting your suspension travel.
What would the insurance be like for an 18 year old on one of those bad boys?
Get a quote and see :lol:
Shh
6.5k... Nice idea though :)
6.5k for insurance on a 1.6 you are joking
he aint joking but i managed a quote of 4k with 1 years ncb and only having a license for 1 year and a month its so easy to trick those websites
Edited by m4ttyf
Yeah lol. I wont have a years no claims until June, and I want to get rid early next year. Well probably after my 18th bday (Feb 23rd)
Well the singer in the band is learning to drive so hopefully she will have passed by then, so she can take the all the heavy stuff in her car lol.
I'm still gonna go for a MK3, I'll just be careful of tire sizes.
Cheers for the help :)
Could go with Cup Car rear suspension. Really harsh ride but it won't scrape.
