Noobie 9n Help!
Hello there, I'm looking at buying my first car very soon!
Either going to go with a 1.2 9n (55/65bhp) or a 1.9 SDI 9n (64bhp).
Was wondering what you guys would think is a good choice? Simple as that!
Cheers! 8-)
  • Views 1k
So 1.2 or 1.9SDI
Can some weigh up the pro's and con's of each motor?
The 1.9SDi will definitely be more reliable and better on fuel out of the two its what i'd go for. The 1.2 has a lot of known problems although I'm not sure if both of the 1.2 engines have the same problems. The 1.2 suffers from coil pack failures and also the tensioners on the chain cam also have a habit of breaking although vw did make a revised part which may or may not have been fitted.
If i were you i'd look at the TDi engines. They are great engines and have very few problems. They arent too much more on insurance either as the 1.4 TDi is in group 5 and the 1.9TDi PD100 is only in group 6. I have the 1.9TDi and its a great car. One thing to watch out for on the TDi engines is the water pump as the original ones had plastic impellers apparently were quite prone ot failure. I had mine replaced with the cambelt when i got the car so that wasnt a problem.
In general the 9N also suffers from badly designed bushes in several places on the front but these can be replaced quite easily. I had the Wishbones bushes go on the way home from getting the car. Mine has also had another bush replaced on the engine (cant remember the name of it) but apparenty they are prone to failure as well.
I've now Polybushed the front wishbones on my 9N, so hopefully I'll never need to do them again. Not too difficult to do, just awkward on your driveway! All 9N's suffer or they will do. Same with the Seat Ibiza and Skoda Fabia.
I test drove an Ibiza 1.2 (2002) before buying my 2002 Polo 1.4S (75bhp). I found the 3 cylinder a bit coarse, a bit gutless, and the ride was awful, but maybe that's a Seat trait! The Polo 9N 1.4, the 4 cylinder BBY engine, by comparison, was smooth in all respects, not quick, but has proven to be very economical & reliable. It's a brilliant little car in a nutshell.
I haven't driven a diesel Polo 9N; I had a 6N 1.9 D CL (1998) for a couple of years; that was a nice car.
