Broken fan /air-blower
The fan/air blower in my 06 plate polo has just developed a fault...it only works on setting '4', settings 1,2,3 do not seem to work..at first i thought it might be the fuse, but as it still works on setting 4, i was a tad confused..anyone have any thoughts?
Not 100% but sounds like the heater resistor has failed, gives the same problems on the Mk3's, only works on full speed nothing else. Hopefully another new Polo owner can confirm this for you.
Thanks, guess that makes sense, yeah it's all or nothing at the moment! Anyone know how to change it/where to get one?
same with my car id love to no how to fix it its doin my head in
There is a guide here for Mk1-Mk3's
Common Fault FAQ
I don't know the layout on the later marks but if you can find the heater/blower you will be half way there.
The manual says to remove the glovebox to gain access to the heater blower unit, the resistor pack is mounted on it, to remove rotate it anti-clockwise and pull up, refitting is the reverse.
