photoshoped
  • Replies 10
  • Views 1.5k
IMO it looks pretty gash. Leave them standard..
Your car though, do what you think looks good.
I dont get what you are trying to do with it?!
Not sure on the wheel colour coding, but i did my set of SE alloys in sparkling graphite myself last year, here's how they came out
it was standard i just wanted peoples opnion on the alloys if i should do them like that?
In my opinion, no.
them alloys look mint! if i sprayed the alloys myself with aerosol can spray and put plenty of laquer on would the look shit or would they look good? and would they peel or anything? I'm seriously considering doing it but dont wanna sand them and spray them if its gunna ruin them and make them peel :/
Depends how well you do it. Weather you use the right primer/ paint, weather you spray it evenly, weather you do it outside in the cold, or in a heated room/ garage.
You can get a very good finish with rattle cans, but you can easily make it like shite.
I don't like the yellow either to be honest. But spraying the wheels black or graphite grey would make it look smart.
Just make sure you deck it once you've done the wheels :)
if i do them it will be in a warm place :) but what paint would u recommend?
bright yellow colour coding? in my opinon its too much like pimp my ride gone wrong mate. its a nice car, i'm no expert but i always think that its the little subtle changes that people find it hard to work out whats different but theres something that makes it a little more attractive than their own is whats makes a car. but maybe thats just me. good luck with whatever you do with it, p.s if your spraying them, do it somewhere warm, dry and dust free and after you've matted the paint make sure the surface is totally clean and dry before applying primer, add coats of colour slowly and build it up, patience is they key to a nice paint finish, once you've got enough coats on that your happy wet sand it with 1500 grit and soapy water then polish it up, then apply a few light coats of laquer and build that up, then wet sand and polish again, people think thats going over the top but trust me the finish is worth it.
I once saw a white '90s Civic 3dr in white. Well I've seen a few,but this one had black wheels,big ones. And it was decked. And it had yellow pinstripe rims.
It was awsome.
This has smaller rims,its higher,and metallic silver,the yellow disc is split and will look like tyrewall writing does when the wheel is turning.. Its likely to fail hard in relation to the Civic imo,but will have its own look.
But why not try it? A very thin test coat will rub off with some thinners,its not about fitting in with what the masses think,you're showing some balls in being inventitive and this is what the pioneers are made of - i say give it a try,even if you just use sticky-backed vinyl to test with.
Fuck what people think,its your car,carry your art - look what my Polo looked like in 2004,not exactly scene but its never raised so much positive attention in public from adults and kids alike..
