Newbie
Hello everyone I'm simon from brighton and new hear. I've just purchased a 2001 VW POLO GTI 5 door and love it so far BUT and yes there is a BUT i have a few problems which need sorting.
1st . the passenger side front wheel is cambering really bad has slight angel on it which i dont know what the problem is ???.
2nd . drivers side wheel is making a clicking noise when you turn right ???.
3rd. there is a slight noise from which i think is gear box when you put foot on the clutch it gose away ??? it dose have a new clucth in it though.
Mods so far well I've just ordered some Black ROTA CUP wheels with 5" lip and thinking of lowering it but not sure how much yet.
Edited by rubadubdub1980
  • Replies 9
  • Views 1.2k
hey dude, welcome to CP, I'm sure sombody on here will be able to help you out, i would like to but I'm hopeless :)
Benn
cheers buddy i might pop along to your meet on the 12th :-)
yes mate definately should :) nice to see some new faces there and this one should be one of the best so far :)
I'm no mechanic but what experience I have had in my huge 5 months of driving I have had 2 maybe all 3 of those problems.
The camber on the front wheel could be the tracking, as this happened to mine. It made the inside of a month old tire bald!
The clicking could be either a wheel bearing or a CV joint?
If the noise your describing is a tiny wine, then it could be the same as mine, I've also recently had a new clutch and it's still there, I asked my mechanic and he did tell me what it was and I can't remember, but he said it was nothing to worry about. Don't quote me on that though as it could be a different noise!
If you have a friend that's a mechanic, get them to have a look. It's not worth spending money on a garage to have a look and tell you a load of stuff that needs doing even though it probably doesn't. I also learned that in my short time driving!
Hope that helps. There are tonnes of people on here that know waaay more than I do and probably ever will, so hopefully they'll give you a bit more help!
Welcome mate you should also try these forums.
edition38.com - huge community
uk-polos.net - more focused on the newer Polos like yours
Welcome to club polo mate to answer a couple of your questions the clicking from the wheel when you turns to me sounds like your c.v joint could be on it's way out as they normally start to click it will probably get louder as well as it gets more worn so worth getting checked out & changed , the grinding noise you describe isn't from the gearbox if you let the engine idle & then put the clutch down & the noise goes it will be the release bearing on it's way out again this gets noiser with time sadly to replace that you have got to remove your gearbox again to get at it .
Steve
what do you think about the rota cup wheels ?
Hi & welcome mate,plenty of answers to Gti probs on here,if you do a search for gti I'm sure your probs will be there! Everyones helpfull tho. Brighton eh,normally come down to brighton once a year in my bus for the Breeze,love the place. 8-)
Very nice mate, they will suit the car down to the ground :p
