lower strut brace
hi I'm sure you all no what they look like few scuffs and scrapes on the bottom but you cant see it and it doesnt effect it so :)
took it off my car when i lowerd it pick up only
say £30? make me an offer its just lieing around tbh
le10 area
  • Replies 11
  • Views 727
anyone just lieing around?
£20 posted if i can see a pic?
postage for the thing will cost me nearly that now they do it on size to you arange courier ect you can have it for 15
Any pics I've never seen one fitted before? I'm not far from you
struts cost just under £5 to post 2nd class via royal mail
thats how much mine cost and it was quite heavy too
well I'm way to lazy for this :p for the gain of a tenner
and its not fitted atm but its basically just 2 bolts on erm well I'm not sure :p I'm sure someone will no what its called its easy anyway
o but if youve lowerd your car over 40 mm well i wouldnt risk it even as a 40 mm drop any speed hump will tear it off easyly sits an inch or 2 down
Well if it dosent sell ill give u £20 posted and take the risk of my car snapping it lol
If its the type I'm thinking of there are people running lower than 60mm that use them so there shouldnt be any issues with 40 if its fitted properly (as in the bar goes over the exhaust)
Have you seen the PPS & PPP "stage 3" subframe set-ups and i have no clearance issues despite how low the frames go.
i have one on my mk2 and it sits higher then the sump does, nowhere near anyspeed bumps, and mines lowered about 90mm
I'm just taking this from when i took it off my car it was easyly the lowest point on the car dont no if it had been fitted wrong then i just took it off it didnt sit over the exuast about 3 inch under it ill get some pic's and see what you all think
