Newbie needing help!
Hi all, I couldnt figure out where to post this soooo,
I have an R reg polo, and I cant lock it :( well I can but its a bit of a pain!
The keys dont turn in the keyholes of either door, I can lock it by reaching across and pressing button down on the drivers side, and have to unlock it by opening the boot and climbing over to pull the button up
Please does anyone know what it is???????
Loli x
  • Views 1k
welcome to club polo
do you have central locking on your car??
so the key doesnt turn in the barrel at all?? one of the easiest things it could be is that its frozen due to the weather, or does it always happen??
if it always happens, it could be that the barrel is knackered.
it could also be that the locking parts have come unconnected.
it all depends on how mechanical you are as to how you go about this...it actually a pretty easy fix or to check.
if it is broken, a simple solution would be just buy a new door handle with lock and key from a scrappy and have two keys or fit an aftermarket central locking kit too it with delocked handles
i hope this makes sense, if you post up where your located in the country, someone kind enough off of here may offer to come help you out
sean
Mine have been a bit frozen in the cold weather.
It may also be a bent key?
these posts come up every year without fail, i too have the same problem to sort with my mates car
i am 99% sure the lock mechanisms will have froze and when you try to unlock it you just sheer the control pin, he did both in the same day, just thought the force would free it
have a look here for a picture
http://www.clubpolo.co.uk/forum/index.php?...=223433&hl=
I had the same problem for a month or two! Luckily its harmless where I live and just didnt lock it...
I ended up buying a remote central locking kit just incase it sticks again.
R-Click
I bought all new parts for the door lock about 6 months ago and due to the cold weather it broke again so I think its best to have a backup!.
one of my first thoughts were that its frozen due to weather i de-ice my locks every morning at the minute...leave the car for 30mins and they need doing again lol =/
has it stopped working recently or has it never worked? cos i got a key for my ignition wen i bought my golf and a separate key for the doors. just a thought but like the other guys said its more than likely they're froze, hope u get her sorted tho
