the bolt that supports the steering column
Obvisouly this is on the steering column but where is it located as I am havin major problem with vague steering, sometimes my steering wheel will be positined slightly left and car going in a striaght line and then i will go over a bump and the car will be going straight and the steering wheel be in-line. I've replace the drivers side ball joint as it was knocking and this problem has now occured any help or diagnosis?
  • Views 599
Popular Days
The column has a support clamp near the top, and a smaller clamp further down towards the pedals. If the second one is loose it can make the steering column feel loose. Was the tracking redone after the ball joint was replaced?
