NEED ADVICE ON LOWERING AND BADGE SPRAYING
Hi, I'm new to this site and clueless with cars.
I have had my mk3 polo for over two years now and haven't done anything with it so just looking for some advice and help really.
I want it a bit lower as it looks so grannified at the moment, but I don't want it ridiculously low so it scrapes speed bumps etc.
What is the best way to do this and is it expensive?
Also, how can I get my badges black?
  • Views 882
Hello and welcome! :)
Probabbly the best thing to use is a 40mm spring kit. You can just about get away with using them on original shocks as well. You can find them second hand for cheap money.
As for the badges it depends on what you mean.. but you can use Back to Black if they were blank and now off black. Or if they are sliver some black spray paint.
PhilJ on here sells lowering kits, you'll need springs and shocks really, as to how low, that is up to you 60/40 (front/rear) looks good. Kits start around the £120 mark then you have to get them fitted, or get a mate who's handy with spanners to do it.
as for the badges, remove them, give them a good clean then sand them with fine wet and dry, clean again, spray with plastic primer, then spray with yuor chosen colour, a couple of coats of each should do, then best to use a couple of coats of lacquer (you can get various finishes) to protect them
Hey, thanks :)
How much is cheap for the springs? I would have no idea what I'm doing or looking for! Would I have to declare this as a modification to my insurance company and would they increase my insurance? The badges were silver now they're kinda white plastic with a bit of silver on them! So can I just spray them while they're attached?
Have a look in the for sale section here there might be one or 2 floating about. You also have ebay and if you are going for new ones then one of our traders can help either Dubstyle or Jackson Tuning.
You should declare them to you insurance as well and it might increase your premium. First thing to do is phone them up and ask them.
I wouldn't spray them attached. you should be able to pull them off. Just be careful of the body work.
