door lock and central locking
197 R reg 1.4 8v
Hi guys and girls.
I'm still in the process of restoring my little Polo as its starting to look scruffy :(
About a year ago the central locking packed in. The mechanic had a look; he's disconnected the vacuum parts so that the central locking is disabled. The only downside is that the key now only works in the drivers door. Its not too much of a problem but I'd love to get the central locking working and have both the drivers and passengers door openable via the same key.
Is changing the locks/handles a real hassle?
If I buy a second hand set of locks and keys will they fit and are the keys chipped/coded to the engines?
Haynes manual makes it look like a fiddly pesky pain in the @rse.
Any tips or advice appreciated.
  • Views 594
You can buy a drivers door handle and key brand new off ebay for £7. It wont have the same key as your ignition tho. Changing them over is a doddle. There is a torx screw on the inside of the door inline with the handle. Just take this out, then pull the handle off. Should take you 5 min max :-)
