6n to 6n2 front end swap
just wanted to know whats needed to do the conversion i know the obvious bumper grill lights wings and bonnet, but do i need anything else?
  • Views 1.8k
Hello mate, someone asked this last week, can't find the thread at the moment but should pop up with a quick search.
Also there is a guy on this forum, jordan_eff who did the full swap to his car, front and back so worth checking his thread out, will probably be in the MK4 gallery.
There's a few fiddly little things like bumper guides and bolts etc. as well as the more obvious bumper bars behind the bumper, slam panel, lights, both wings, bonnet, all grilles, grille badge, splitter.
Also, i'm unsure about the wiring.
On the plus side, pretty sure the inner wings are the same, so should all just bolt straight up!
The wiring is different, too. The 6n uses H4 light fittings, and the 6n2 uses H7, so you'd need to convert them over, too.
Although not hard, it's still a bit of a job.. :)
