Removing rear wiper
I need to take the rear wiper off on my 6n as it seems to be one spline too high so the wiper runs off the rear window. Is this simple? and how because the washer is built in?
Cheers.
remove the plastic cover at the end of the wiper arm (over the end of shaft) i think it just unclips/flips off.
undo the nut (i beleive it is a 13mm spanner/socket size)
remove wiper arm, if its tight give the wiper arm a gently bash with the palm of your hand, if its really really tight give it a spray with some wd40/penetrating spray and go for a cuppa then repeat.
when its off, put your ignition on and turn your rear wiper on, let it stop, then turn it off, this will be in its rest position.
put your wiper arm on at 90 degrees (they have 180 degree rotation) remember to put it on the right side in accordance with which direction it turns! if not youll be wiping your boot.
put back together.
if it still has problem most likely the park sensor within the mechanism!
put back together.
Thanks for that buddy! Will give that a wirl!
