mk3 bumpers on a mk2
Any tips for fitting mk3 bumpers on my mk2? I'm guessing that the rear will just bolt straight on. but does the front bolt straight on or do i need to mod it to fit my current bumper bar
  • Views 784
The nack takes a bit of plastic work to make up the arch gap, and a few bolts into the bottom of the rear valance make it stay in the right place. Then you have the little issue of lighting up the plate, espoeccially with the boot lock being there. IIRC I cut a cavaliar plate light on.
Front's a bit of a fucker. trawling my memory back a lot of years, I think I used the mk2 bumper bar so I could retain the indicator mountings and fitted some pads to support it. Again you need to make a bit of a skin up for the trailing edge, and shorten the bumper because of the mk3's longer overhang.
