mk 2 dash
anyone no if a mk 2 facelift dash fits a mk2 with a non facelift dash
  • Views 1.4k
It can be done, but the later dash is too long for the earlier door cards.
Tar m8 what about just changing the clocks do they just plug ing and fit in the non facelift dash?
anyone coz iv got a problem with clocks
when i put lights on not full beam the full beam light cums on and oil light
put full beams on and they both go out
if i go 2 side lights the temp light flashes 4 about 10sc then stops then the temp gauge flys up takes about a min to get to top
If i play with the dimer and dim it right off the temp light cums on but dont flash
cant work it out
plz help?
Wrong way around. The Mark3 dash is shorter to accomodate the contoured front edges of the Mark3 doorcards. This would leave a gap on either side between the dash and the doors when you fit a Mark3 dash into a Mark2.
  • 3 months later...
cant work it out
plz help?
i have this problem after taking my mk2 speedo ect out, then putting back in. something must be wired wrong? also when u use hazards the dash light stays on and they wont work
