MK2 bready front crash - can it be saved?
Any mk2 driver will know what i mean when i say, the brakes didn't stop me, and it would be a merc with ABS that pulled an emergency stop infront of me, anyway.
I got a knackered mk3 as a replacement and it's nice but is has a huge dent on the back. Which one is more repairable because both will be MOT failures, just the breadvan's ran out 1 week after the crash.
Any one with experience that can advice me on weather this can be repaired? cos if it can, the mk3's going and I'm keeping the breadvan - else its going to the scrapman.
(The breadvan Mk2 1988)
http://i1142.photobucket.com/albums/n611/S...n/IMG_04341.jpg
http://i1142.photobucket.com/albums/n611/S...n/IMG_04361.jpg
The wing can be replaced, it just crumpled a bit under the wing inside the bonnet (second picture)
Any ideas on feasibility/price to repair?
  • Replies 16
  • Views 1.7k
as long as you can get the headlight alignment it should be fine
looks like everything can be replaced, but the crease could do with some chop n weld...
Thanks for the info - if it's a welding job i'll leave it. I've got a mk3 with a beatup back but that can just be pulled out - plus its got MOT.
Thanks anyway.
you could bash most of that straight with a big hammer. it depends how pretty you want it. it certainly isnt what i would describe as major damage
Depends what it's like underneath. Best thing to do is get the wing, bumper, grill, light off and see how it looks from there. Instinct says it's faxable, but you never know without a good look in person.
put the new wing on then use another car thats heavier and attatch a rachet strap to the towing eye and where ever your car needs to be pulled and just tighten the srap until everything lines up then hit down any high spots loosen off the strap treat any bear metal and then put it all back together and it should be perfectly fine but wont look perfect.
mk2 doesnt look so bad
as said bolt on the new panels and see where its all at , what I've done in the past is chain it to a lamp post or similar and push the car back , the momentum should be enough to help tweak it out
as long as the panels are bolted on and the headlamp is aimed it wont fail a mot for a dented inner wing
Thing is I'm in my MK3 with MOT 'till June, and i'm on a v.tight budget. The mk2 is completely solid immaculate and only done 40K compared to the mk3 that has done 90k and while it is solid, its a bit of a wreck (with a big dent in the back - it doesn't effect the lights but could cost more to repair - trying to gauge.) However seeing as the mk3 handles alot much better - may just switch the interiors and scrap the mk2, possible isn't it? and it wouldn't be criminal to scrap a good example of a mk2 :cry:
Car is being used daily to commute and will be for the next 4 years (student) mk3 i'm guessing will be more reliable but is it not possible to convert mk2 to injection etc. ? Having said that the 10K I put on the mk2 (in 4 months) were trouble free as in not a hiccup apart from the dodgy choke which i sorted a few days before the crash and it all worked perfectly. The mk3's boot doesn't close properly from the dent in the back (previous owners) and it's been playing up (cutting out) in the 1000 miles i've done.
In the wisdom of all posters that have experience - I have these two cars - I need something reliable. Which one do I use? Lightly used mk2 with FSH after repair or stick with a battered mk3?
they're the same car basicly , so no reason one should handle better than the other
if you want to keep the mk2 then the mk3 tyres and suspension should all swap over , and yes the injection engine does too
assuming by mk3 you mean mk2f
having owned numerous mk2 and 3 polos i have to say I've always found the mk3 a more reliable car. why not just sell the mk2 on, then have some cash in your pocket for a rainy day. the mk3 spi injection is a doddle to fix. the cutting out is probably just a dodgy blue temp sender or possibly the throttlebody/injector assembly (again a very simple fix)
Cool - scrapped mk2 put the interior and wheels on the mk3, gonna service it Friday and run that. Thanks for your helps!
be nice to sell some spares on here before you scrap it
One word, RAT! Just an idea ¬¬
if I had the cash - that would be fecking amazing!
You don't need money mate thats the whole purpose of rat, get a grinder take some paint off the bonnet, leave it a week or so to rust then £3 for a can of spray laqcuer. get some old lino the stuff you use for kitchen floors, stick it to the roof, put some fride magnets on and a couple cuddly toys on the towhooks, sorted :)
