Just had my winter check done
so i had my winter check done on my car to see if i needed anything done and turns out i need 3 things done
at this time of the year i dont want to be giving away money when i dont have to so to get to the point is it possible to do any of the following (bit of a noob at mechanics but like to give it a go)
*new indicator switch
*n/s/f wheel bearing
*leaky cat seal
  • Views 1.2k
cool
Indicator switch - possibly. Get a haynes manual and it will tell you.
Wheel Bearing - this one may well be a complete pig to do without the press they use to push the old one out/new one in
Cat Seal - stick some exhaust putty on it :lol: sealed up :thumbsup:
@ nepolo- cheers mate thanks for the actual advice :D
Nobody uses their indicators these days,usually swinging round the junction too fast for it to be any good anyway.
Whip a hub off a donor car in a breakers. Take the indicator too if you can be arsed.
Remove exhaust clamp,part joint,clean off old cement,join with fresh paste and use a new clamp.
Mikey you must of missed the sign on the MK boundry that says "Indicators are not required in this town, espescially if you are a Taxi or Bus driver!!"
Haha!! As a former resident of MK this is definately the case! :)
