How to remove front seats
As title really, how do i remove the front seat's to replace them with 16v ones??
TIA
  • Views 1.3k
Theres one bolt under the front of the seat, I believe its 8mm... turn anti-clockwise
Also a few bits of plastic trim that cover the runners, these should just clip off
Should slide all the way foward, then undo the bolt under the front in the middle, slide all the way back and out.
Pete.
Really that easy, cheers :thumbsup:
Its a wonder they hold up in a crash :lol:
Ok, so now that they are out, what do i do to fix their freedom in the brackets?
Freedom in the brackets? guessing they wobble a bit? there's a white plastic piece in the middle of the mechanism on the floor, that'll need replacing.
Oh, thanks a lot mate.
