Spraying body parts
Hi people,
has anyone DIY sprayed their car with non matte paint cans and actually metallic colour coded ones. I'm thinking of spraying my rear bumper myself but my car is colour code LN5Y - Windsor Metallic blue and seeing as its a metallic should i just not bother spraying it with cans and go to a body shop ?
  • Views 874
Hello my brother.
I wouldnt personally do it unless you have a compressor, as believe me I've sprayed a lot of stuff (like hundreds of car parts) with rattle cans and quite simply you will never get the same finish. If uve got access to a compressor or someone with one, give that a go, at the right temperature!
If not go bodyshop man. Its not that expensive if you make friends with them and promise more work. Like I did. haha!
Hope this helps
Matt
the man above says it all tbh....my local garage only charges like £45 a panel so cheap enough or me...dont use rattle cans ever unless using matt, just doesnt work!!!
All depends on how you want your car to be, I personally don't care that much for paintwork so i just used cans.
think ill just try getting friendly with a local bodyshop then :lol:, although I've got a friend wiht a compressor and that but not sure on how that will turn out, so many choices lol
