newbie polo gti 6n2 owner
Hey guys n gals,
Although i put newbie I've had my little polo gti for 4 years....just not bothered with it much as I have spent al my time and money on my Mk1 Caddy.
However i thought it was about time I spent some time and money on Polo.
Its a 51 plated Gti in black with 63k on the clock. Bought it 4 years ago when I was working for VW. It came in p/x against a 1.8t gti.
Anyhows its been driven by the gf since then.
Been solid as a rock for 4 years (only serviced once) in the time...and i only did oil and filter. Brilliant little car!
So gonna throw a bit of cash at it...full service..full exhaust....induction kit...coilies etc etc.
Know quite alot about mk1 golfs but very little about the polo.
So any recommendations/advice on more in depth tuning? superchip, re maping etc etc?
Thought you guys would be the ones to ask!
  • Replies 12
  • Views 1.7k
Welcome :thumbsup:
if you're gonna drive it like you stole it then i'd suggest a stronger 'box i think its applicable to the GTI it is with the 16v
I would go for a set of JOM coilovers to get it nice and low. Perhaps if you haven't already done so delete rear wiper, badges at back? Nice set of OEM wheels something with dish?
Hope it helps!
hmm have had the gearbox strengthening mentioned before. I dont drive it like I stole it....but my gf does! so could be an option. I was wondering what would be involved in putting the 6 speed from the Lupo in. Does anyone know if its a tricky job? I've done gearbox conversions on my mk1 caddy but thats a rod change linkage and relatively easy.
As for the coilies I'm only doing a sensible drop...50-60mm.....trust me....with the missus driving and the speed bumps round here 100mm would be insanity. Going to stick with original bbs as I like them. Polished lips with black centres. simple but effective.
Bodywork wise....remove the rubbing/bump strips from doors and rear quarters and get it resprayed (at the same time fixing crack in rear bumper and dent in n/s door and quarter....both from the gf! grrrr. lol )
Sunday if not covered in snow is the sports cat...good service...pioneer headunit....comps up front and my JL audio 700w rms digital amp and 15" sub in the boot! It rocked in my caddy van which I just sold so it should fucking kick like the jolly green giant in the little polo. lol
Thanks for the advice though guys.
The gearboxes are fine, ignore the un-educated reports of them being crap. Just check the seals for leaking fluid, especially the shaft selector seal as they are prone to leaking. Low fluid will cause damage to the 4th and 5th gears as they sit the highest in the box. The main weak-spot of these gearboxes are the rivets holding the diff/final drive gear together, these have known to regularly fail and should be replaced with bolts.
The 6 speed from the Lupo is not a direct fit, the bell housing is a different design so won't fit without major work.
I would recommend a full service as these are normally done every 6-10k on the GTi's. The engines are harsh on the ignition components, spark plugs, coils and HT's.
The cambelts are due every 40k or 3-4 years and have a known weak tensioner. If yours hasn't been done since you've owned it I would personally make it a priority.
I would VAGCOM check the car to see if it's running right before I would modify anything. A good service and any fault codes removed will do wonders. Check the readiness of the engine so it's performing it's best.
The first port of call when modifying would be a good induction kit and cold air feed. Something along the lines of an enclosed filter, such as a BMC CDA. These engines suffer from heat soak so if the filter isn't enclosed it'll do more harm then good.
Next would be a good 4-branch, sports cat and exhaust system. Raceland are the cheapest for the 4-branch, but these are not a direct fit as they are made for all the 16v engines, as a result they need the EGR valve thing removing and welding up prior to fitting. heat wrapping is recommended to remove heat from the engine bay and aid in heat soak removal.
Remaps can be done for about £200 at most re-map places. I would get this done after the above mods to get the best gains.
But saying that, these engines are crap to tune. Expect an extra 25-30 bhp with the above mods.
Edited by MrP.
i said i wasn't sure if it applied and in my own experience i have had with the box on my valver it was knackered so I'm on its second and it is weaker than the 8p box
I wasn't having a dig, people just say they are bad with no explanation. It's the same components on the inside. It's the extra power the boxes struggle to deal with.
Edited by MrP.
mine was probably the dirty pikey of a previous owner ragging it
MrP thank you for that valuable info!
Didnt think the bell housing would be different tbh...thought the main problem would be linkage set up. Think after what you just said the 5 speed will be fine! lol.
Well then its a bloody thourough service and cambelt first. Then sports cat and cat back system and then the induction. will get that lot spot on before lowering me thinks.
Cheers guys for your input.
How can you possibly say the gearboxes are fine? You are a lucky one to not have had problems, but I guarantee you if you have it long enough it will crap itself! You then go on to say the diff rivets are weak. It's a shit box - simple. It's not uneducated people saying this, it's people speaking from experience. Virtually everyone who's owned one has had gearbox problems.
As for up to 30 bhp from a filter, exhaust and remap? Are they really that badly restricted from standard? If anything I'd have thought it was the head and cams that was restrictive.
i have had a replacement box
Personally dont think its worth engine tuning. Its only a 1.6 125bhp is pushing it quite far as standard surely? For the amount of money you would spend for small power gains, not to mention the extra stress on what is already a comparatively brittle and delicate engine/gearbox set up theres just little point.
Go for a BMC CDA if you want a bit more noise but otherwise id just leave it as it is or move on to a car with more tuning potential that hasnt been pushed as far from standard i.e. 9N3 GTI 1.8t 150bhp.
Edited by jam3983
