porche tombstones
alright guys got some porche tombstones that i want to go in the polo but have no runners for them, could i take the seats running gear of standard seats and bolt onto the tombstones?
would this be an easy job or will it require welding etc
cheers guys
boydie92 :)
  • Views 830
wont bolt off/on
will need some cutting and fabrication work ..so no not easy, but plenty have done it
cheers dude, appreciated
what you want to do is get yourself an angle grinder take your original seat out of the car.
Take the seat upright from the bottom base think theres some screws either side,
Then you want to take all the foam and material off the base
You want to angle grind all the small spot welds either side of the seat pan and remove this
The bar that loops around like a U shape you want to chop the U shape into three sections and take out about 3inchs from the middle of each side leaving about 3inches on one side and 3inches on the other at the rear of the seat frame where the runners are and about a 3-4inch piece of tube at the front that is now separate.
The seat frame should be able to move freely up and down.
You might want to chop the rear part down about an inch to make the seating position lower but then you need to weld the rear two parts to the bottom rear of the tombstone and the little bit of tubing left at the front goes under the seat into the metal seat frame and welded under there.
Hope this helps as its how i did mine but i gave them to an engineering company to do the welding as i cant weld yet
