Frozen Shut..
Just this morning and 2nite my drivers front door is frozen shut and it wont even unlock until its warm..?
Any other experience of this?
  • Replies 59
  • Views 7.2k
Could always try getting warm water from house poor it over the lock......
Anyway it always happens to me and even if i do get the door open it refuses to shut so i have to put the door to and push the lock down so the door dont fling open.
how do you think i feel with pillar-less doors! Watching that window bend is scary shit!
But yes. Warm water around the outside. Job done.
Not boiling because obviously that would be stupid
Adding to that, i actually got locked in my car this morning once i parked up door froze solid, i eventually managed to KICK my rear doors open.
after i wash the car spraying some wd40 in the locks work a treat when it comes to freezing mornings.
The warm water didnt help this morning.. really anoying!
Neil.. what mods do you have to your TT?
purring warm water over the door can cause this, i used to do it but once it had frozen by the time i got to the petrol station on the way to work, i had to climb out and back in through the passenger door. thing is once you do it once you get into a routine where you have to keep doing it to defrost all the water that you poured over it before :lol:
pink fluffy steering wheel cover and play boy mats.
When it's dry, spray some silicon (or at least cheap furniture polish) on the door rubbers.
Its a 225 quattro with apex 40mm springs, BBS LM reps, AMD remap to 270bhp. Forge silicon intake pipe (getting rid of the squidgy oem one) and forge DV valve, hard wired hair straightners and fake tanning booth in the back.
Its pretty boring really. Just plenty of toys to keep me amused. Good daily motor!
FYI... I'm a technition at The TT Shop :D
My doors no longer freeze shut since I applied vaseline to the seals (turns out it has more than one use!) and also when your locks are dry spray plenty of WD40 into them if you can, this will prevent water from building up to an extent. Or, you could just buy a 20 year old BMW with heated locks as standard.
Funny thing is i didnt use water this morning, and i keep meaning to walk to my garage but such effort :(
Rele not looking forward to my car at 7am...trying to get into it :( however the heated seats will be nice once I'm in :D
mine no longer freezes because there is hardly any seal left :lol:
Just as good :lol:
your my new best friend!
sort me out some adjustable rear tie bars!
I hate the TT forum though. They all think there driving veyrons!
Haha i agree.. when in fact they are nothing to our TTRS :D
The drivers door froze solid on my Laguna last week...I pulled on the handle so hard the french shit plastic inside broke and now the drivers door won't open from the outside :(
This is why I've just sold a pug 206...
I've found it easy to get into my polo however the citroen not as easy even with central locking
aaaaaaaarrrrrrrrrrrrrrgghhhh! took me ten minutes to get into the other halfs ibiza. earlier in the day she had poured warm water over the doors. by 10pm this had frozen the locks so bad i had to get in through the boot, crawling under the dog gaurd in the process. one was not amused. i hate semi modern cars. never have this prob with my polo or my mk1 mx5
My door lock froze open which was really annoying as the car wasn't at home so couldn't use the warm water trick. Also, as the lock was frozen open, I could lock the car and then with very little effort, open the door. It was as of there was no lock. luckily, i live in an ok area as I had to leave car unlocked all day!
I had that last year! Then the lock decided to snap off when I tried to open it again, passenger side was broke already. Had to open the boot of my MK3 Golf cabby, get a a skinny mate to crawl in and open the door but ,putting the key in the ignition and then he could open the central locking from the inside. Not a good look!
i use a lighter to warm the key up and put it in the lock and wriggle it about for a few secs.
sod putting warm water on it as it makes it even worse next time
