changing break hosing? hard?
yeah basically my drivers side braided hoses were to long and rubbing agianst the wheel and finally wore through today hence a break down and couldnt break haha.
got a replacement stard set, are they easy to fit?
a quik step by step would be nice if poss?
and guessing having to re bleed the break system aswell after changing?
cheers in advance
  • Views 755
A flexi hose I assume? Fairy easy. Just loosen the nut at each end of flexi, and then replace the hose, do nuts back up. Simple
Brakes will need to be bled yes
Use a brake pipe wrench,not a normal spanner.
