Clutch 1 Steve 0
Pretty shocking tbh, I was driving yesterday and decided to go through the back roads as there was alot of traffic going on, forgetting the speed bumps and ice. So i had to use my engine brakes all the way, managed to get all the way through then pulled out and it sounded as if it was crunching but it was still moving in gear?! so i pulled over straight away and just decided that i had to leave it there. Having no money at all as I've just finished my christmas shopping it couldnt have come at a worst time :/
And this ridiculous amount of snow isnt fucking helping :(
  • Replies 8
  • Views 1.4k
Well if you had just gone slower you wouldnt of needed to engine break, and the backroads are going to be far worse!
so the clutch was still working just making a noise? no slipping?
I was driving slower?! I just asnt using the brakes as the front wheels lock up. Surely thats common sense? :retard:
Guy it still runs as I drove it back yesterday, but it doesnt whine it whistles. Works in 1st 2nd 3rd and reverse but obviously I didnt go any faster to see which other ones did. So what do you reckon?
it doesn't sound like the clutch has gone mate, if it was going it would slip and if it had gone it would be like every gear was neutral. if the clutch is engaging as it should and working with no slippage i'd be very suprized if that was your problem.
when does the noise happen, is it only when the clutch is released or when it's pushed in? or is it when the car is driven?
Tick over is fine, usually when i press the clutch in and then take my foot off. Press then accelerator (sp) then let go as its just drifting along? Very weird tbh... Usually (before the snow) It died when it was cold as i changed down into first it would stall if that has anything to do with it?
so...
when you have the car running in neutral there is no noise?
with it still running and out of gear put the clutch in and out and still no noise?
then put it in gear and drive it and the noise is there?
if that sounds like what you are experiencing then i think your gearbox might be going rather than the clutch. best to get a second opinion as it's not an exact science when your trying to diagnose a problem like this over the net but it does sound more gearbox related than clutch.
Awesome...
I did notice a slight leak on the gearbox when the new engine went in. So it might just be oil? I hope it is :/
Cheers guy :thumbsup:
yeah well worth checking the oil level if it's got a leak mate, hopefully that's all it is :thumbsup:
