Pioneer Deh-P800BT head unit
Pioneer DEH-P800BT
Bluetooth CD Tuner (Handsfree and Audio Profiles) with iPod Direct Control
Get connected - without the wires.
Make and receive calls wirelessly, as well as stream music via your Bluetooth CD Tuner: the DEH-P800BT supports both handsfree and audio profiles from your mobile phone. This means that you don’t need any additional in-car kits, cradles, wires or headsets.
You can take your digital music collection in-car, too. The 800BT plays every audio file format, but you can also connect your iPod with the CD-I200 connector provided. Alternatively, if you have a USB music source, you can also connect it using the optional CD-UB100 adapter.
Made for iPodYou can control this CD Tuner with its ‘rotary commander’, which works very much like a joystick – essential for navigating through your WMA, MP3 and iTunes audio files.
Powered by our MOSFET 50W x 4 amplifier, the DEH-P800BT has 3 RCA pre-outs, so you can boost your in-car set-up with additional amplifiers, subwoofers and speakers.
Features:
* Max. Power Output: MOSFET 50W x 4
* Tuner: AM/FM
* Plays: CD-R, CD-RW, MP3, WMA, WAV, AAC
* Bluetooth: Yes
* Front Panel: Auto-flap mechanism (motorised)
* Display Illumination: Dot-type OEL
* Button Illumination: Blue
* Rotary Commander: Yes
* Remote Control: Not included
* Multi-Language Display: Yes
* Cellular Telephone Auto Muting: Yes
Technical specifications:
Connectivity:
* Aux-in: Yes
* iPod Direct Control: Yes
* RCA Preout: 3 (F + R + S/W or NON-FAD)
* Hard-wired Remote Input: Yes
* Direct Sub Drive: Yes
* High Voltage Output: 4V
* Full Control Expansion Units: Multi-CD, TV, Multi-DVD, USB
* Partial Control Expansion Units: DAB
Bluetooth:
* Handsfree Telephony: Yes
* Audio Streaming: Yes
* Battery charging: Yes
* List Browsing: Yes
* Music Playback: Yes
Tuner Features:
* Radio Data System (RDS): Yes
* Traffic Announcement: Yes
* Best Stations Memory (BSM): Yes
* Preset Channel Memory: 24
* PTY Search: Yes
* CD Player Features:
* CD-R/RW Playback: Yes
* MP3: Yes
* WAV: Yes
* Windows Media Audio (WMA): Yes
* iTunes AAC Playback: Yes
* MP3 Text Display: Yes
* Disc Title Memory: Yes
* D/A Converter: 1-bit
Audio:
* Low Pass Filter: Yes
* High Pass Filter: Yes
* Graphic Equaliser: 7-band, with 5 preset EQ curves and 2 custom
Price is £70 full image of screen not showing but can be repaired, hence the price. Item is for collection only
Edited by jit
  • Views 466
Where are you based? or would you post if too far from MK?
I'm in hatchend. head unit is for collection only
where are you based? if its not far i can meet you half way or something
  • 5 months later...
price drop to £50
