just found these on ebay if anyones intrested
  • Replies 20
  • Views 1.7k
I put money on that being dknight.
it certainly is
ha i only put them on yesterday!
been meaning to start selling these for 2 years to be exact! just never found the time and previous supply disappeared.
The items them selves, well what can i say, they do a great job, all the points in the advert!
I have them on the website too, but for some reason the text has gone a bit haywire, I'm working on it, dont know why but all the "fi" in the text have disappeared lol
cheaper on the website too
www.axlespacers.co.uk
I'm sure the other mods/admin will not mind me replying in here, trading on here is pending
Also happy to say if you are a club member on here you get a nice 10% off
Nice one dan, proper professional
well i will definatly be getting a set of 10mm ones after xmas.
will these do a 6n ?
i am just sorting out what cars they will fit, but i am 99% sure they fit 6n's
Can you do more than 3x5mm spacers on each side? Ideally I want 25mm spacing on each side of my ibiza GTi, and these work out a bit cheaper than hubcentric spacers.
on the website it goes right up to 30mm if required
http://www.axlespacers.co.uk/
Yeah I thought that means 30mm altogether, so 15mm each side? I shall more than likely purchase a set after xmas, how easy are they to fit?
Edit: Just realised it says 6 Pairs now lol.
Edited by patchb
yeah its ok the description is confusing sometimes, 15mm gives a nice stance on a mk3 polo, simple enough to measure up tho, fitment is easy enough, just a matter of removing the rear brakes and then the stub axle, unbolt, fit spacers, put back together, jobs a good un!
here are some old pictures of when i fitted mine
So ideal to do if you were renewing your brakes anyways really.
hmm seems like a better option than conventional spacers. If theyd fit a bora id be interested.. once the snows gone
DK
do you have a set there that you could mesure the hole pcd ?
i know they are not in a circle but mesure hole to hole , as i have 6n2 stubs sitting off the car and i'll mesure them
i could measure them but it is a generic pattern from what i have found out, so if it looks the same, it will be the same
if you want you can get a face on picture of them and measure, i can check it if needed?
i'll go mesure the stubs the now
looks like the same shape to me
Do these fit 6n2's? I want some.. I don't like using conventional spacers..
I reckon you'll have trouble getting the brake pipe and handbrake cable to fit if spacing out more than more than 15mm per side. I would probably go for a combination of these up to 15mm and then a smaller normal spacer behind the wheel. In fact this is what I am doing on my g40 to give a spacing of 21mm on either side to hopefully sort out the stupid thin track on the rear of my polo.
Yeah you're right, my house mate had 25mm each side on his Mk3, and as a result the handbrake cable snapped as it was under such strain.
I haven't had any experience of these style spacers but I think i'd rather fit a longer handbrake cable just to be on the safe side.
yep, i had 24mm ones on mine. got them from PPS
44435_483260605328_582110328_7112553_538
wasn't worth it, i had to make new brake lines, and modify the handbrake cable, but obviously as it was a 20 year old cable it wasn't up to much. Snapped the night before my mot, so i took them off and sold them.
15mm would of been more sensible, but i got it sat like this, on et38 wheels...
45631_425107341828_577716828_5386552_680
