Wing mirror casing replacement? please help
HI
I've got a 1995 1.3 Polo 2dr, i think this is Mk4? and for what is worth its a crazy green color, not sure what paint is called. might be electric green
Some tool has smashed into my drivers side wing mirror! the colour casing is fine and the electric motor part still works but arm etc snapped inside. If I get a replacement from ebay in all sorts of colors.
Can I put a replacement wing mirror on and take the original Colour casing of the old on to put on the new one?
Is this hard to do, replacing casing if it can be done.
do i need to take the inside door card off to change wing mirror?
Many thanks
Dan
  • Views 1.7k
HI
Many thanks
Dan
33 views no reply!! dones noone know? helllpp!!
I've moved your thread to the technical section, you'll probably get more success there.
you are efficient mr yeti
Got a spare dragon green casing for passenger side.
my casing is ok , its the rest of thw wing mirror thats knackered, but cheers anyways.
So, can you separate the coloured casing from the rest of the wing mirror mechanism ?
thanks
Dan
Nah, just bored of wrapping presents.
