wheel bases mk3
basically I've been trying to find out the wheel base for the three versions of the mk3 the loon the breadie and coupe but I've had no luck as of yet just wondering if anyone could help me with this as it has something to do with a rather crazy plan of which you shall all soon see
  • Replies 24
  • Views 2.5k
2337mm on them all according to Autodata.
Yep, I've got it as 2335mm here for Mk2 and Mk3s, but 2337 is probably just slightly more accurate.
On a guess, a tank of fuel probably makes more than 2mm of difference.
Sounds about right, mine's 2350+/-5mm but it runs a lot more castor than stock.
my old 1989 mk2 coupe was 2340mm on drivers, 2325mm on passengers.
i set them both to 2340 when fitting a stage 3 subframe#
edit to add the 'I' incase theres any confusion as to me stating others to 'set them both to 2340'
Edited by grungeisdead
thanks guys anyone know the wheelbase of a hilux
About 100", a Suzuki Jeep's a pretty good fit... search for a user called "ollythedolly"
cheers bud
that isnt high I'm thinking proper lift kit and big wheels mini monster style
are you planning on making one of those mini-monster truck things by rebodying a hilux with a polo shell? Would be pretty funny to do although I dont know what you'd actually do with it since I doubt it'd be road legal. I'm trying to find the mk1 fiesta one I've seen pictures of but I can't
Don't see why it wouldn't be, So long as it keeps the 4x4's identity, as opposed to the Polo's, then it'd just be a modifed Hilux.
The hilux is separate chassied, so as ong as this isn't modified, you'd avoid SVA/IVA.
It's only like building a beach buggy on a Beetle floor.
i like the way this is going :lol:
as said tho SJ would be best and they can be lifted pretty high
you mean a suzuki jimny guy or is it actually called the suzuki jeep
just to clarify though this is most definatly not happening to the loon it will be a coupe or a bready thats not mot worthy i couldnt destroy a good dub
they are also called suzuki SJ mate
i think a mk3 loon cut down in to a pick up would be the best looks wise, and when made into pick ups the proportions work a lot better than the square backs.
wont be my loon and i have an idea where there is a shell of a mk2 loon
couple of pics i took at edition a couple of years back that might interest you
thats possibly the strangest pick up I've seen and weirdly its quite nice i have progress tho I've found an sj chassis and running gear local and cheap so watch this space
mk2 loon , back chopped off and modded ?
Correct, and a squareback tailgate used to make the back of the cab.
thats bloody awesome!
Just beware of the rust on the chassis rails and particularly the rear cross member.
If it's an old skool SJ, as opposed a new Jimmy, they're sprung axle over leaf front and back, so they're a peice of piss to lift (just flip the axles).
cheers for that bud the frame has little bits of surface rust here and there but is solid and the rear cross member is new as are alot of the other components the guy was going to off road his but got bored thankfully
depends how you interpret the "rules", fairly strong argument to say that beetle based beach buggies would now need an IVA too. I'd wager on getting pulled approx every five minutes driving about in a mk3 polo mini-monster truck :lol:
97~02 2.4D 2850mm wheelbase, front track 1395mm, rear track 1370mm
