Front end damage on my Mk3 coupe :(
Right, On my mk3 polo, just below the lights and grill and above the Front bumper, there is a layer of metal!
from a bump into a car, the layer of metal and my front lft wing both have alot of damage!!
I was just wondering if this part can be taken of the car and replaced aswell as the wing??
Not worried about colour coded parts as the whole car will be going satin blue When the new parts are on :)
Any help would be great :)
  • Replies 9
  • Views 1.5k
Anything can be replaced if you have to skills and knowledge :lol:
Thats front valance only be replaced by cutting out the old and welding i personally wouldn't bother and just change the whole front panel for the same amount of work. You might be lucky and it might be bolt on but am not sure of this as it might be a bit ''modern''.
not quite sure what parts your describing here but sounds the same as mine and what i had to replace have you any pics of the damaged parts and i maybe able to guide you to replacements and how to remove / replace
The wing just bolts on, but the grill rail's part of the front panel, which is welded on.
i replaced it on mine. Easy job to do if you have the equipment.
Its spot welded on, so just drill the spot welds and it will come off.
Then spot weld the new one back on
The pattern panel can be picked up for around a tenner.
I'll see if i have any pics of when i did it.
Offending panel
Off
New one on
There all the pics i have, but you get the idea of what to cut where etc
Edited by B-shaw
yeah i was going to say the same as b-shaw.
There only spot welded on and a few bolt here and there.
Best fully stripping it down and looking for mega creases under the arches and cracked joins under the bay.
You have to weigh up the costs too, Is the polo worth it?
It needs a good job doing as come Mot time i wouldnt like to place any bets to wether it will pass if you do a shoddy job.
Thanks everyone :) have got 1 picture and i reckon i will give it a go at fixing it when it gets a bit warmer, which is going to be a while :)
  • 3 months later...
thats nothing
thats nothing
That's helpful :lol:
Although the damage isn't really that bad, should be able to just straighten it out rather than replacing it. I took mine off a while ago as it had been repaired before and had been bolted in place instead of welded, painted te wrong colour and put on upside down, was a right bodge...
However just took it off, straightened and painted it then spot welded it back in place, pretty simple tbf
