6n comps
I'm looking to upgrade my standard comps before soundproofing and building a sub enclosure etc, was jsut wondering how many people just replace the mids and tweeters unamped on standard wiring? obviously amping them would give better sound, but i cant budget for that :/
thanks
  • Views 1.2k
anyone?
I've tried it before and i would honestly say you would be better with a set of coaxials if you are running off HU. comps need a bit more power like you said, amping.
I've just got a pair of 6.5" JBL GTO coaxes, kenwood HU, JBL GTO1214 sub and JBL amp and does everything i want for a budget system - for the money it sounds mint!
go amped with comps or coaxial
problem with going amped is that youll never be able to go back to hu power as the sounds so much better
thing is arnt comps fitted as standard in the polo? or just replace the door speaker with co-axials?
They would run fine unless they are competionn grade stuff , mine are fairly high end ( mb quartz) and I am current dunning them off the head unit since my amp sh•t the bed, sure there not amazing but they still do the job and are still a decfinate improvement over the stock setup.
Co azials wold probably handle about the same refardsles, but if your planning on building a larger system in he future then getting a decent set of components now would make more swnce then buyng a set of coaxials now and then anther set of components later.
