5 speed gearbox code: 085 8P
I'm after an 085 gearbox for the mk2 golf if anyone has one that their willing to sell.
Edited by vee-dub90
  • Replies 11
  • Views 3k
anyone?
anyone?
for a mk2 golf?? the 085 is not a gear box code it is a tipe of gear box use on the mk1-4polo's and some golf's but there is diffrent codes..
i have a gear box of a mk2 polo coupe S (gear box code 8p)
anyone?
well its for a 1.3 mk2 golf, and i just got told the code for it is an 085 box :? as it will be a direct fit for the mk2
I've got a 5 speed off a 1 litre polo?
An 8P will fit, got one off a mk2 1.3 golf for my lads 1.3 polo ;)
Been told I may have to swap one of the dif output flanges to fit it on the polo
i am selling a 8p box off a mk2 polo.. the 8p wos neva fitted to the golf's
if you wont the proper box for the car you nead to tell us the gear box code coss ther is 100's of diffrent codes for the 085 box
it wos fitted to :
polo
golf
typ 2
passat
jetta
sciroco
vento
most of the vw range
coss this is a polo forum so finding golf bits will be hard. so do you wont a golf box or a polo box?
coss what i am trying to get at is a 085 box off a mk4polo will not fit on to a mk3polo coss thay are diffrent
Spooky! Picked my gearbox up from a golf breaker and was told it came off a mk2 1.3 golf. Checked the code on the gearbox which i'm positive has 8P stamped onto it. The breaker told me to check the output flanges against the old gerabox as one would be different. Will have to double check when I get back to my garage.
its for a mk2 golf.
To check the code, look on the top edge of the bell housing between the engine and the inspection hole. It's awkward as it's under the dizzy, so you may need to use something like a scourer and a torch to be able to see it properly ;)
its for a mk2 golf.
this is club polo
well i cood sell you a 085 8p box from a mk2 polo but will not garantee it will fit.
its for a mk2 golf.
this is club polo
do you know if this gearbox will fit the 1.6 aee engine? and have you got one?
