Avoiding traffic noise!
Hi,
Thats prob one of the weirdest topics around here...
My mission in life from now on is to make the car so immune to outside noise I could here a fly farts in the back seat!
Now I've heard its all in the rubber... or is it?
whats the steps i should take?
Thank you .
  • Replies 14
  • Views 1.9k
line the car with audio sound deadening?
http://caraudiosecurity.com/shop/product_l...facturers_id=61
Sorry for doubting your recommendation, but I don't wanna hear music but instead i want to cancel outside noise wind noise and such, that would prob help no doubt, but it wont make it perfect, so besides that any other suggestions?
(I am still ordering the Superlite Tri-Pack Sound Deadening kit so thanks, any pics of how to apply it correctly?)
I reckon the Dynamat would help quite alot.
This may sound strange, but I find mine noticeably louder inside even with the rear seats folded down. Exhaust noise is more intrusive.
Could try and put sound deadening round the spare wheel well, and maybe some at the front under the carpet to keep the engine noise out?
Other than that all I can think of is changing your tyres for quieter ones, and perhaps renew door/window/sunroof seals if you're getting wind noise?
Is it a whistling wind noise?
fresh door seals, aero wipers.
tyres will help
Aero wipers? what are those?
And would you guys know where i can purchase all the new seals?
(except for VW! over here, apparently, they think its an A8, just the door seal is 550 euro!!!)
And yeah with the seat down/off it's louder by much, the catalytic converter was bad so i had the
magnaflow installed all of a sudden it was noisy inside (the weird thing is it wasn't from the outside)
so i had to put it back on...
Any kits for A-pillars maybe? it is mostly the road and traffic noise.
(for better explanation i also have an ML350. after that you get into the polo and it's like you
are sitting on the bench next to a highway. Now i know the purpose and price difference is huge,
but i told the girl the polo stays and she said than u don't use the ML on daily basis to justify it's
existence. so i said no more ML. polo only, and I'm not gonna back down so help me out here).
Edited by Eat-My-Dust
If you want to get really serious with sound deadening then the following will help:
completely strip the car interior back to the shell
fill any voids in bodywork with expanding foam
double,triple or even quadruple coat entire internal surfaces with sound deadening matting (this may need to be trimmed back later to allow panels to fit)
fit everything back in
renew seals, fit aero wipers, more aero dynamic mirrors and remove rear wiper. basically you want to make the car have the best aerodynamics it can, its the friction of the air running over the car which makes noise.
quiet tyres
make sure all bushes in engine, exhaust and suspension are not perished, correctly seated and, if necessary, greased.
Obviously make sure nothing is hitting the underside of the ca (exhaust hung properly etc.)
should be pretty damn quiet then!! :)
Thats exactly what i'll do, in the mean time, the interior is almost stripped, i have the dash and the carpet still on (i am driving it so...).
Also, any ideas where can i order the seals and the foam?
btw, i can feel the vibration of the engine, it's pretty ruff, and i checked the motor mounts, they are in decent shape, any ideas?
engine is pretty smooth running but on low rpm you can feel it's rotation.
I'm not sure if you can get them for polos but there is such a thing as a hydraulic engine mount. These massively reduce engine vibration being fed back through the chassis. Even if they are available though, they're not cheap!!
I'm not sure where to get replacement seals from, but the foam you want is this: http://www.hilti.co.uk/holuk/page/module/p...;nodeId=-333461
This stuff uses the moisture trapped inside the foam once it has been sprayed to cure it. That means that no moisture is left in the foam itself which could otherwise lead to panel rusting from the inside! I wouldn't recommend spraying this in doors though as window and door lever/latch mechs will be a nightmare! Put matting on the inside skin (where the door card attaches to) and the inside of the outer skin (if you see what i mean!)
Obviously the larger the panel or void the more it is going to resonate, making it more noisy, so these are the ones to concentrate on.
Hope this helps! :)
This forum never disappointed me, great people :wink: .
Thanks a lot.
If anyone has anything to add you are welcome...
And so another journey begins ( I can see myself driving with no interior for like 3 months till the finish but whatever :lol:
thats how you spot a real car lover right? )
no problem bud! :thumbsup:
I just looked at the Superlite Tri-Pack Sound Deadening kit, if i was you id go for something like the 1/4" dynaliner instead. This is an adhesive mat instead of a "loft insulation" (sorry i dont know how to put it better!) type thing. This twinned with the expanding foam will give you a much better sound insulation than foam and the tri pack deadening kit. I also means that panels are much easier to cover. Basically the idea you are going for is an entirely re-skinned interior in sound deadening mat! This will hold all the panels much tighter and will definately make the sound insulation more effective!
The matting is also very easy to fit. Its basically like a flexible lino tile, you peel the backing paper of and stick it down!
Note: i would go for either the 1/4" or 1/8" mat myself. But if you were to use 1/4" then you will only need 1 layer!
Haha my journey never ends with my polo, i fix 1 thing and another thing goes wrong, still love it though!! :)
If it was ok than i wouldn't like it at all.
It's LEGO for grown ups.
I would treat it as if it was garbage or korean.
but this way you get to know the car, and you are to busy for drinking/gambling/doin drugs !
bottom line, its a hobby. (expensive one)
Also, is there anyway to order the rubber door seals (grey/black) from germany? (thats of course assuming i dont live there)
And how the hell to i upload pics from picasa over here?
Places like http://www.carbuildersolutions.co.uk sell various door seals by the metre. You can probably get one slightly thicker than stock,needing a firmer action to close with better sound proofing results.
They should also have the essential thin self adhesive seal that goes around the outer door shuts and in the groove around bonded windows,as its ideal to stop the noise whistling across the gaps in the first place.
Hey thanks a lot...
That site is very usefull.
