Paint Colour
Hi all, the paint code given on the sticker shows it to be LD5D Chagrall Blue? When I take any pic's of the car it comes out as shown in the first pic, but when you see it yourself it looks more like the second pic more of a purple! I have just received some paint I ordered, based on the LD5D code and it is more of an indigo blue, so I don't know if they have mixed it wrong? I know the bodywork could do with a good T cutting as it's a bit dull, but I can't see it comming back to the colour of the paint received and I don't think it has been resprayed by a previous owner?
  • Views 1k
The paint suppliers should have mixed to the correct colour for the code given, when new. You can double check the colour by calling your local VW parts dep' with the reg/chassis number, say there is no sticker and ask for the colour and code ;)
Edited by philpheasant
I had originally called the stealership before I found the sticker and they also gave me LD5D.
As soon as it stops snowing I'll try to compare it with an area that has not faded, like the underside of the tailgate, but I can't see it being a match! I have called the paint supplier and he's certain that the mix is correct, if so the car is going to need one hell of a T cut and polish!!
