How to remove the handbrake cover - Polo 6n
Hey,
Just wondering how to get the plastic cover off the handbrake?
I know how to remove the base part so you can access cables for adjustment etc, but I need to remove the plastic cover off the handbrake lever itself?
It looks like it just slides off, but I think there must be a clip or something I need to remove to get it off.
I dont really want to break it if it can be helped.
  • Replies 8
  • Views 8.1k
just pull it up and it unclips :)
what the long plastic bit which goes from the button to the pivot point? Not the bottom surround trim??
Sorry, i misread, I thought you were trying to adjust the handbrake.
Are you wanting to remove the entire lever? it's just a couple of nuts, undo the handbrake cables and unplug the switch.
no just the plastic trim off it to replace with leather lol :) but i need it off to modify to suit etc!
i want that plastic off ;)
mk3 golf vr6 leather one fits iv seen a it on here somewere I'm going to do it wen i fined one un clip it undo the bolts twist the whole thing it will cime out the cables then reverse to put back in
to just get the bit you hold that bit of trim off look under the handbrake like where your hand goes the should be a tab get a screw driver flick it out can be tricky the it slides off
yeah i was just replacing the gaiter, done it now, found it on elsawin :p knew there would be a clip somewhere, cheers.
