tint spray (which is better?)
which tint spray is better in quality savage 400ml can or e tech 150ml can considering I'm gonna make the rear lights almost black
yes i know it wont pass mot but thats y I'm gonna get spares from college car haha
also do i need to spray the inside of lens or outside?
Edited by dancharge
  • Replies 12
  • Views 2.1k
I always use the Savage with a few coats of lacquer on top ;)
ok thx whats the best way to clean the tailights i was thinking of using some form of alcohol or white spirit would that be right?
I gave mine a good wash let them dry, then rubbed with 240 grit and cleaned again, three coats of tint (you may need more for proper black) another rub down and clean, then three coats of lacquer to finish
finger prints wiped off :lol:
ok I'm not sure if i can get 240 grit but is it nessasary can i just use white spirit and when you say another scrub down do you mean with the 240 again?
Edited by dancharge
Wet and dry (like sand paper), used 600 grit the second time on the tinted surface. Used to provide a 'key' for the tint and lacquer to stick to
Edited by philpheasant
ok thankyou i know its a pain but can you give me full instructions on the whole procedure start to finish as i really dont want to get this wrong it will be much appriciated
will sort tomorrow ;)
thankyou ill come on again tomoz about 7-8 ish
Remove the lense units and give them a good wash all around the outside, washing up liquid and a foam backed scourer work well. Rinse the lenses and allow to dry.
Decide if you are removing the markings, part number/e number etc. if you are removing them, start with a sharp craft/stanley knife tring to keep the blade level with the lense surface. Once removed use something like 240 grit initially, then a finer grit like 600 or 800, and rub the whole lense area including the sides.
Then clean the lense with something like white spirit and a non fluffy cloth.
Now you can spray the tint, use the instructions on the can, and spray as many coats as you desire over all parts of the lense including the sides. Once finished leave the lights for the tint to dry completely (overnight is good)
Take your now tinted lenses and lightly rub all over with your 600 grit or finer, and wipe over with white spirit (must be fully dry or you'll damage the tint coating
Your on the home straight now, just cover with a few coats of lacquer and leave to dry, overnight if possible.
Then simply refit the lights.
Hope this is of use ;)
thats fantastic mate thankyou once i get the can ill get right on it and post up the pics and btw merry christmas
I used etec on mine, the light shines through good and the finish is nice as well considering i rushed it.
the police have only mentioned them once and i've never been pulled over for my lights.
Once the laquer has hardened (the lights will have been on the car a couple of days), use some polishing cloth to give them a bloody good buff with some Autoglym super resin polish. This'll get them up proper shiny.
This can also be done on naked standard tail lights to restore them.
