removing bump strips on side of car
as title says looking at removing the black bumpstrips of side of my 6n2 are they jsut stuck on?or they clipped?
cheers
  • Views 1.2k
On 6n they come straight off with abit of hit water and a scraper/wire. 6n2s they are stuck and clipped so when removed the holes will need filling and respraying.
I believe they are stuck on by strong glue. The best method to remove the horrible buggers is. Get a credit card slide it down one of the side and pull it away from the car. Hopefully some of the bumper strip will release itself from the car. Then get a hairdryer and gradually start burning away the glue. As the glue starts to go pull the strips part by part away untill it's all gone. Thats the easy bit done.
Thats the easy bit done, believe it or not.
After you've done that you've got the horrible task of getting rid of the horrible sticky bits left on the side of the car. I would try and do this ASAP or it'll only be harder to do if you leave it.
Get some white spirit and use a CD or something with a sharp side to remove it. Its a pain in the bum to do but your car will benefit from it after and you'll love it!
Hope this helps.
so there are clips or arent?? cheers so far guys
lol spose u dint read them properly,gonna guess clips is final answer n not glue,cheers guys most useful
no they have the gluey stuff much like a 6n but clips also.
therefore when you remove there are holes which need to be welded filled and smoothed and painted
