PLASTIC BIT UNDERNEATH GRILL?
The this plastic thing undernearth the grill at the front.. which also dips under the lights abit.. what's this called?
And how do you get it off? are there clips behind the lights or something idk.. lol
  • Views 707
Grille surround.
Presume 6N? The early ones were actually metal.
Remove the indicators and you will find a 10mm bolt that holds the trim in place and some clips between the headlights
Trim >09.99
Removing and installing radiator grille with trim frame
‒ Turn signals removed.
‒ Remove combi bolts -4-. Release locking lugs from deflector -3- (Qty. 2) and radiator grille -1- (Qty. 4) with a screwdriver.
‒ Pull radiator grille with trim frame off.
Radiator grille
◆ Material: ASA
◆ Removing: Release upper and lower locking lugs with a screwdriver. Pull radiator grille off trim frame.
Trim frame
◆ In body-colour
Deflector
◆ The part has been gradually discontinued in series production.
Combi bolt
Edited by nige8021
