polo is doing me in!
The polo mk3 is doing me in... :-( drives fine and then stalls normally when coming off the power and then is a job to start. Its getting more and more frequent and takes longer to start. Have changed:
-plugs
-fuel filter
-distributor cap
-rotor arm
and has a ignition coil on its way
The fuel pump does work, when turn key it pump for 3 or so sec then cut out. so dnt think its that
any idea
thanks rich
  • Replies 11
  • Views 1.5k
have you tryed the Distrebutor? best too test out a mates dissy or go to the scrappies to get a cheap one.
when warm or all time?
I'd say temp sensor
What's it like starting in the morning?
Could be hall sender
yeah could be temperature sensor (blue one iirc?) more likly this than the dizzy.
Easy fix and cheap :)
It does it when its worm or cod but normally warn got a distributor and coil park coming so will try that.
Thanks for the help peeps
sorry for butting in ...where the hell did you guys get that a temp sensor will cause it to cut out ....
hi all have changed the coil runs better but still does it. the funny thing is that it can idle for ages with out cutting out. I'm really :?
help rich
checked all your hoses for air leaks?
iv resealed the inlet and carb, the hoses are in gd nick
quite simple really.
If youve never owned a mk3 polo then you probably wont know.
Its a common symptom. They overfuel and run like shite pop fart and cut out when you drop the clutch rolling upto lights etc.
hi all which sensor is it the one on the back of the head or the one in the thermostat?
thanks rich
