Mk3 G40, mk2 Coupe S & few 6n parts.
Hi guys and girls, right most of you know by now I’ve been breaking my fairly high spec mk3 G40 and a mk2 coupe S and many other parts I have gathered over the years and this is more of less what I have left.
Everything listed from the G40 has done 60K and everything from the coupe S has done 54k, if your after a bit you can’t see on the list be it trim, engine related, anything drop me a pm and I’ll see if I can help.
All prices are including postage (to UK mainland only, if your outside this drop me a pm and I’ll try to sort you a postage quote) or all parts are available for collection from Suffolk on request for a reduced price.
All part number are correct to the best of my knowledge but please appreciate some of them are printed on paper labels that have been stuck on parts for over 20 years in some cases so if you think the part number is incorrect for the part you need let me know and I’ll try to double check it.
If you are buying multiple parts, as long as I can get all the bits in one sensible sized/weight box you will only pay the relevant postage for that parcel, please contact me to discuss this further if required.
Also please note where I have listed a part as “G40” or “Coupe S” this in no way means it will only fit that specific model, its just what car that part came off. Please verify using the part number what models parts will fit or if that’s a problem or its an aftermarket part please contact me and I’ll do my best to help you out with what fits what.
So think that’s about it, any questions just ask, and pictures of most things are available on request.
VAG Mk2 Coupe S drive shafts (both sides, they have surface rust but work as they should) £15 each or £25 the pair.
VAG 085 gearbox shim plate £6. 2 available.
VAG Mk4/6n polo full stock suspension set up (struts, springs the lot) £50
Brand new sytec Motor sport inline fuel pump 234L/h @ 3Bar £110.
Brand new Forge Motor sport polished alloy header tank with cap £85. (this is a early mk2 golf tank so has no sensor provision built in, and fitment is fairly universal if you mount it yourself)
Brand new Serck cooling MK2 polo spec radiator (pattern part) £30.
Brand new Mk4/6n polo badge less grill (plastic frame with silver mesh insert) £20.
Brand new set of 8 genuine VAG G40 hydraulic followers £90. (VAG part 034 109 309 AD)
Used set of 8 G40 hydraulic followers, only done 60k £25. (As above)
VAG G40 exhaust manifold good condition no cracks £30.
VAG G40 header tank and cap £7.50. (VAG part 357 121 407 C and 357 121 321 A)
VAG G40 pressed metal ring (cant for the life of me think what its for, 3 bolts hold it in place and its about 3” diameter) anyway its powder coated gloss black £6. (VAG part 030 121 048)
VAG G40 oil splash guard (head, internal) £5. (VAG part 030 103 478 B)
VAG G40 oil pressure sensor £6. (VAG part 056 919 081 C)
VAG G40 air box £17.50. (VAG part 871 129 611 C)
VAG G40 radiator and sensor £17.50 (VAG part 867 121 253 AB
VAG G40 DP/Cat bracket & hanger £8.
VAG G40 inner driveshaft flange guard £6.
VAG Mk2 polo MH engine alternator bracket £10. (Useful for G40 turbo conversion maybe?) (VAG part 052 199 185 C)
VAG Mk2 polo Coupe S rocker cover bolts, washers & rubbers, set or 3 £10 (VAG part number for rubbers 030 103 533 A)
VAG Mk2 polo Coupe S pressed steel rocker cover £15. (some surface rust but no deep pitting)
VAG Mk2 polo expansion tank cap £4. (VAG part 171 121 321 C)
VAG Mk2/3 polo upper gearbox mount and bolts £7.50. (NO RUBBERS, ready for powder coat?)
VAG Mk2/3 polo lower rear mount bracket and mount plate £7.50. (NO MOUNT)
VAG Mk2/3 polo engine mount + bolt + big washer £7.50. (VAG part 867 199 383 A)
Brand new genuine VAG Rear brake cylinder bleed valves and dust caps £3. (VAG part 113 611 475)
VAG G40 master cylinder and fluid reservoir £12. (VAG part for res 868 611 307 A) has surface rust but works as it should.
VAG Mk2 polo Coupe S master cylinder and fluid reservoir £12. (VAG Part for res 868 611 307)
VAG wheel brace £5. (VAG part 191 012 219)
VAG wheel brace £5. (VAG part 171 012 219 A)
VAG scissor jack £8 (VAG part 867 011 031 B) 2 available 1 black & 1 gold.
VAG G40 front wiper motor and mechanism £20. (VAG part 868 955 113)
VAG G40 stock camshaft pulley £10. (VAG part 030 109 111 B)
VAG G40 stock toothed crank shaft pulley £12. (VAG part 030 105 263 A)
VAG G40 stock twin “V” crank shaft pulley £12. (VAG part 030 1?5 255 C, ?=8 or 9 I think, VW drill a locating hole through the part number!)
VAG/Hella drivers side head light £20. (VAG part 868 941 016)
VAG/Hella drivers side clear indicator £7.50 (VAG part 867 953 050 A)
VAG Mk2 polo front indicator £6. (VAG part 171 953 049 J)
VAG G40 black “VW” boot badge (complete with the rubber cup it mounts in) £7.50 (VAG part 357 853 601 B)
VAG Mk2 polo “POLO COUPE” boot badge, chrome effect £5 (VAG part 871 853 687)
VAG Mk2 polo “VOLKSWAGEN” script badge, chrome effect but well weathered £4 (VAG part 321 853 685 C)
Mk2/3 polo NON cable adjust wing mirrors (both sides and all fittings) £25.
VAG chromed door lock mechanism £8. (rear door golf/jetta maybe) (VAG part 893 839 015 D)
VAG G40 plastic radiator surround £10. (VAG part 867 121 284 F)
VAG G40 4L washer bottle NO PUMP £8. (VAG part 867 955 453 D)
VAG MK2/3 polo grab handles, b pillar ones, pair. £5. (VAG part 861 857 637)
VAG G40 under dash trim, passengers side £15. (VAG part 868 857 921 B)
VAG G40 ashtray assembly and cigar lighter £8. (VAG part body 868 857 307 & tray 868 857 309)
VAG G40 rear strut plastic covers and foam, pair. £6. (VAG part 867 512 135)
VAG G40 sun visors, black, pair. RH has slight split on clip bar, £10. (VAG part LH 867 857 551 A/B & RH 867 857 552 C/D)
VAG G40 dash blanking plate (for under headlight switch) £4. (VAG part 868 857 145)
VAG G40 rear lap belt and buckle mechanism £8 (VAG part 191 857 837)
VAG G40 rear belt double buckle mechanism £8 (VAG part 867 857 739)
VAG G40 front seat belt assembly + all bolts etc (pair) (Consisting of VAG part 867 857 705 B, 321 857 841, 191 857 737, 165 857 732) £10 each or £15 the pair.
VAG G40 gear knob £4. (VAG part 161 711 141 A)
VAG G40 interior light and bulb £4. (VAG part 191 947 111 C)
VAG G40 front wiper arms £10. (VAG part 868 955 706 A)
VAG G40 rear wiper arm £5. VAG part 871 955 706 A)
VAG Mk2 Coupe S rear wiper arm £5. (VAG part 871 955 707)
VAG G40 grill with black “VW” badge and a Volkswagen script badge £17.50. (VAG part 867 853 653 G and 867 853 601 A) (this grill is very good condition with all the clips intact, however its had 2 of the little vertical bars removed and a Volkswagen script badge stuck in the space, looks ok imo, have pictures if required)
VAG Mk2 polo hazard light switch £6. (VAG part 162 953 235)
VAG Mk2 polo rear heated screen switch £6. (VAG part 162 959 621)
VAG Mk2 polo rear fog light switch £6. (VAG part 162 941 535)
VAG Mk2 polo centre consol £10. (VAG part 871 863 241 B)
VAG G40 heated rear screen switch £6. (VAG part 535 959 621)
Let me know if you are interested,
Cheers Lee
Edited by leeg40
  • Replies 75
  • Views 4k
Hey I'm intrested in
VAG mk3 polo “GT” grill badge £6 (VAG part 867 853 699 A)
VAG dipstick tube and dipstick, used but only done 2k £10. (VAG part 030 115 611 F)
PM your paypal please
Edited by popdragin
pm'd about the clutch: Helix 4 paddle ceramatalic clutch (G40) new £275. (cover plate#604719, drive plate#764719)
interested in these..any pics dude?
have you seen how many items he has listed, that would take hours! lol
coupe s badge sold to me.
Lol, i was thinking thats, you after pics of anything in specific?
PM'd you back dubownerbilco thanks for spotting that.
sorry forgot to paste.. :p
Brand new weichersport alloy rear strut brace fit poloI-III, £35. (Part no S16007)
Brand new weichersport steel lower front brace powder coated gloss black £30.
i can vouch for lee, bought parts off him over on the clubg40 forum and they arrived well packed, in top condition, perfectly as described.
buy with confidence :)
i'l take the green stuff pads... does that include postage... and do you paypal? cheers.dan.
oh yea.. do you have the rest of the g40 exhaust, i'm after cat back for my s...
Edited by dandestruct
could you send me a picture of the mk2 coupe s alternator please,
cheers
Pm'd
ebc disks and pads sold... cheers.
ill have the dipstick tube if its not gone already and the throttle cable braket ill take, also have you got the braket that holds the wiring connectors on the inlet manifold ?? if so ill take that aswell pm please
have you any wheels at all?? :-)
also is the header tank brand new or not ?
Pics of lower strut brace if not already sold please. I assume it not a GED bar right?
Sorry now sold.
Cheers Lee.
You have a PM.
Cheers, Adam
List updated, plenty sold, plenty to go, hopefully be adding more parts this week.
If your interested in anything drop me a PM, prices are open to negotiation.
Cheers Lee.
Hi
Brand new genuine VAG 239mm stone guard/cover plate one handed pair £30 (VAG part 867 615 311 B and 867 615 312 B)
are these the same as the mk2 ones that attach to the struts? just behind the wheel?
Any more details on the rollcage? pictures, how many points etc etc?
cheers.
roll cage, fuel cell and mk2 coupe S shell sold to me.
Edited by Oily Fingers
List updated, more stuff added, more to come.
think i will grab that coupe s alternator off you in a couple of days as mines starting to play up :(
Edited by vee-dub90
