06 polo 5 door boot wont open
Anyone got any ideas how i get in ? let alone fix it.
  • Replies 8
  • Views 2.8k
i had the same problem, u need to take the plastic cover off from the inside, then theres a small link rod that had come off u need to reconnect it then it should be alright
Fold down the rear seats?
Cheeers mate, the covers screws are obscured caused its shut :? i might have to rip it off and get a new one.
Edited by vwjohn
The Polo's of about this age (on the 9n/fabia chaiss) has a wiring fault in the boolid.
I take it you font have a boot popper on your remote? And is it just one of them weird electric boot releases?
If so then the washer pipe freezes and allows the pipe to split allowing water to leak into the main solonoid connector on the wiring loom. this corrodes quickly and doesnt allow power through to realse the boot lock. I just had this on the Fabia VRS I have - fixed by cutting the connectors off the wires and wiring them directly together.
No mate mines not got remote central locking. I've just got the key activated one.
Where is the boot release mate?
Should be on the dash?
Can't see it mate, any pointers as to where it is :?
