"kangaroo juice"
having this problem where my engine is shuddering now and again usually on a cold start can understand it.... it is the same kind of this as you get when u hose down your engine (obviously i haven't done that) what would cause this? could it be spark plugs? any help appreciated.
  • Views 732
It sounds like a misfire, this could be caused by, as you say, spark plugs (I recommend genuine VW plugs), plug leads or a faulty distributor cap. ( if you change that, treat it to a new rotor arm as well).
There are other possibilities, but you have to start somewhere and the above items are not too expensive and may be ready for changing anyway.
Regards.
