What Is The Size Of The Seat Base On A MK3 Polo Coupe?
As title really, i need to know from bolt hole to bolt hole as i am trying to fabricate some M3 seats to go into my polo,
Yeah i know its going to look frankenstein but i love the seats, they are so comfy and i need them in my polo :-D
Cheers Guys
Tim
  • Views 810
There is only one bolt that holds mk3 seats on, it's at the front in the centre at the front end of the rail. Your best bet, would be to get a pair of old seats and strip the bases to utilise the frame. Fitted pug leathers in mine, did take a day of measuring, cutting, welding, fitting, cutting, welding etc though.
Ok great,
any way of just drilling holes in the floor of the polo, re-inforcing with some thicker welded steel and bolting to original floor using the original bmw base?
Cheers mate
Can't see why not. You would want to check inside and out where you are driling to ensure you don't go through any cables or brake/fuel lines ;)
