6n2 Gti Turbo
I've done a search and couldnt find anything so ill start this.
I'm looking to turbo my 6n2 gti.
But obviously i dont want to strap one on and blow every component.
So I'm hoping their recommendations for people i can talk to about it?
Any help would be great..
  • Replies 47
  • Views 9.1k
  • this is what i would do in fact its what i did i pick up my circa 200bhp mk3 cupra on monday hopefully
think its easier to 20v turbo it
^^ not really..
I've been looking into it too. Not so much turbo, but supercharging.
I guess it would be recommended to upgrade the pistons and other essentials,
It would be epic. just go to a garage that can offer that service, they should know everything!
You'd be at least £1000 for the uprated rods and pistons you'd need, plus god knows how much to rebuild the gearbox to actually handle the power, then the cost of management, turbo, manifolds, etc. If you can weld to a good standard and work things out, then a 20vT may be the more sensible and probably cost effective option.
Ask the chap with the supercharged 1.4 16v on here about internals....
I had a 20vt golf and it ruined my wallet with petrol.
I'm willing to spend 1k on it as it will be friggin amazing.
I would charge it but I love the sound of the turbo
dont think 1k is quite enough, its quite a big job really!
A grand might just hack it if you did absolutely everything yourself and relied on a few 2nd hand parts... Otherwise no.
I think a gearbox which could handle the torque would be most of your money gone straight away.
I didnt mean maximum. I dont mind as long as it doesnt take the p!ss.
Stuff like that always ends up taking the piss. Whatever your budget is your likely to go past it. There will always been unforeseen things that you will need to do or hiccups along the way. I can't imagine a 1.6 16VT is gonna be massively more economical than a 1.8 20VT.
i doubt the mpg on a 1.6 turbo will be much less than a 20vt!
stop being a pansy and get your wallet out for a 20vt install.
Diesel gearbox, much better than trying to load a polo GTi gearbox with 200+bhpz
it sounds to me like you need a PD150 conversion in your polo, tune the fucker up and have infinite fun handing people their ass in your new diesel weapon while still getting nice mpg
I'd love to do a dirty PD conversion in something!
What's a pd?
Noob here :)
Pumpe Duse it stands for i think.
just the later diesel engines in Vw's
from a mk4 golf GT tdi etc.
Plenty of torque!
What's a pd?
Noob here :)
as said the pd is a modern turbo diesel engine found in vw and audi car's, it's the diesel equivalent to the 20vt. they come in (iirc) 110, 130, and 150bhp flavors but are only a remap away from a lot more power. it would be pretty much the same work as fitting a 20vt into your car but would be more friendly on the wallet and it would be a pretty cool conversion, i've never seen on in a mk5 polo before?
What's a pd?
Noob here :)
My A4 is a PD 115.
The 90 & 110's are the TDI's previous to PD.
Won't the require changing the filling tube and tank? Possibly fuel lines?
opposed to pistons, conrods ect, ect, ect,
id definatly rather change a tank and lines over internals of an engine with a chocolate gearbox, get it done it'd be nice to see! theres a fella sellin a mk4 pd150 on here putting out around the 200bhp mark i think.look in for sale section
EDIT: http://www.clubpolo.co.uk/forum/index.php?showtopic=208532 - serious machine!
Edited by ben.r
i've converted a few car from petrol to diesel and never had to change any of them. i guess it all depends on how its set up on the car the engines coming from, but even if you did have to change them for some reason you could probably use those from the TDI mk5 polo. although the only possible thing i could think of you needing to change in that respect may be the in tank fuel pump if they run at different pressures, that's not really a big deal tho.
That's it.. I've decided to make mine a 1.6 turbo.
If anyone could possibly list the things I'll need to do and need to buy, that would be great. Need as much info as I can grab. Thanks :)
There was a thread called '4 Cylinder Turbo Spec List' but I cannot find i nthe search to post the link. Anyway I had kept the Info for reference ;)
Written by don_stavrou
I have noticed alot of people ask about turbocharging and how to get more power out of there polo's so figured i post up this specification list i wrote up a while back when i was thinking about building a Polo 16vT
Keep in mind this is to do it properly!
Dimz
STAGE II
GT28R £575
Exhaust Manifold & Downpipe £400
Intercooler £200
Intercooler Pipe work £100
Gauges and Pods £75
Air filter £60
Dump Valve £100
External Wastegate £???
Turbo Fitting Bits e.g sump, oil feed, oil cooler £100
Machining £300
Squirters £????
Headwork £1000-2000
Forged Rods and Pistons around £1000
Big End bearings £60
Main bearings £75
Turbo Cams £350
Head gasket £60
Exhaust Valves £130
Head Stud Kit £130
Fuel Pump £100
Plugs NGK’s £40
Injectors £120
Clutch £500
Standalone ECU & Wiring Kit £850
Miscellaneous Items £300
3”/2.75” Exhaust System £400
Big Brake Kit £1000
LSD £550
Wiring and Mapping (£????)
Removal and Refitting of Engine (£????)
TOTAL = £8,575
Big question is whether the gearbox/driveshaft’s can handle all this power and can you lay it down? This setup is would be mad and seriously fast..
Keep in mind that this doesnt include labour or the cost of mapping and any extra bits you will need for the build!!
Wow.. I really didn't think the list would be that big.
Let's consider a 20vt haha
