anyone ever replaced the bbs rm centre badges
hi guys i have some centre caps with bbs badges in them (09.23.221) but there water damaged and cracked has anyone ever replaced the bbs rm centre badges? i can get a new set for close to £50 posted which i think is steep to say the least, just wondered if there are any stick on type???
I've seen some nice ones by storm developements but they dont seem to pick up the phone or answer emails!
  • Views 710
Well if you didn't want to spend that much you could easily measure the diameter and have stickers made at a sticker shop with the design you wanted i know my friend had that done by http://colchestersigns.com/default.aspx
There's a few copyright issues there to get bbs ones made but I'll fond something!! But I have found a say to split them! Just stand it on edge and tap the edge with a hammer and eventually it pops off then you can slide a flat bar/screwdriver etc under the shiney bbs bit and again stand on end an tap the bar with the hammer! Then you will be left with a flat centre cap on which to make your own caps with!
