need help
i was blackening the bumpers of the polo last night when i reached into it to get in behind the slats to clean as far back as the plastic goes and as i was rubbing around rust hit the back of my hand, as it turns out the entire panel behind my front bumper (dont know what its called, slam panel or whatever) is rotten, i need big time help, anyone know of any mk3 polos being scrapped? i need a solid front end or my plans for the car will go down the drain and i dont want to let it go or sentence it to the scrappy, porsche seats and alley cat wheels waiting for it and i need to get it finished.... plz help
  • Views 1k
Look round your local scrap yard, there's normally a few mk3's in mine which are solid. If you don't fancy taking a saw then just nicely ask the staff if they would gas axe it out for you, it works for me :lol:
Either that or patch it up with a bit of welding, it doesn't have to look perfect, just needs the rust cutting out and fresh metal putting in. There's always a way, don't loose hope :-D
not losing hope mate, been to the scrappys already, none there. and its too far gone to weld.. need to get one from somewhere tho
Have you taken the bumper off and assessed exactly how bad it is and how big the rotton area is?
What Rach said :thumbsup:
Get the front end stripped off and have a proper look, it's not normally more than the bottom bit that goes.
its my daily so hard to get the time to get it stripped, if i can get the whole thing and just have the front end stripped and replaced in one go it'd save me time. if any of it is rusting i'd rather replace the whole thing anyway as i'm planning to finish the car and keep it so may as well do a thorough job, cheers for the advice tho!
That's ok, best of luck. It's always best to do a thorough job if you are keeping the car long term 8-)
