Quick bit of help
Right, I'm going to get a mk3 (mk2f) dash, I'm just wondering are all the plugs for heaters etc the same? i know the speedo instrumental panel one isnt but I'm going to be using mine anyway. Just need to know if they are the same for the heaters, indicators etc.
Cheers,
Liam
  • Views 835
This is what i found when i was interested in doing it, Think most off the plugs are the same.
The dash swap is more than just a bolt in job.
The steering column support bracket that is welded to the bulkhead is a different shape and fouls the back of the dashboard. To get round this, you have two options...
1, Cut the bracket away and weld in a Mk.3 item(what I'm currently doing)
2, Cut the back ot the dashboard and the clocks away to clear the support(not very professional)
There are other issues too such as relocating the lower brackets(easy) and one or two wiring probs(nothing too major). You will also need a Mk.3 column as the Mk.2 lock sits in a slightly different place and will look odd in the Mk.3 plastics.
I have loads of Mk.3 dash parts that are going in the skip this weekend. If you want any to play with, come and get them for free!
Edited by MaxMax
Hmmmm cheers for that Max. I'm gonna try find sme examples, and have a god read into it. Or i could just go for it and jump the obstacles when they arise.
All depends if your using the car as a daily drive doesn't it mate.
I'm trying not too at min, but hmmmmmm. Gonna look around for a build thread or something. Get an idea of the work .
