Pic request
As title really. Have a steering damper to fit, but I'm sure I have the wrong parts. If someone could show mr a pic, I could see if I had the right bits.
Thanks in advance
  • Replies 22
  • Views 1.3k
i cant be arsed to take a pic :lol:
Take a pic of yours and show us? haha
there might be a pic in my build tread if you can be botherd to look for it
I'll try and get a picture. But it just seems like my steering cage doesnt have enough holes :? The whole of the steering and suspension isn't anywhere near the car ATM! :lol:
Renegade, I shall have a browse through your thread, any chance of a link to it though, please :roll:
If the rack didn't have the damper originally it'll not have enough holes iirc, as Ben noticed this and robbed the brackets off the GT for his.
Matt
I have the special bracket that holds the steering rack to the bulkhead, which I know is specific. It's the other end that's the problem. Apparently thy can be used with a standard mk3 cage, but I can't see how. I have an mk2, so I guess that may be then problem :?
The bit that holds the track rods?
there you go, as removed from a GT yesterday
ben
Perfect mate, I'll go cross reference
No probs mate, glad to help. The damper goes in the 3rd hole on the front of the cage
ben
And is that the way it points too, the thin end under the steering column end? I'm sure I don't have that 3rd hole, which is a bitch
Edited by prankstar2003
Any help?
That's perfect, thanks a lot
they dont have these on the 1.0 or standard 1.3 do they ?
Edited by vw-nay
Fortunately not.
Why do you say fortunately? Do you not rate them?
My 1.3 CL has the elusive 3rd hole.
Matt
this may sound stupid.. but why would you want to dampen the steering? is that not just reducing the feel of it? and thus the control of the vehicle?
Its not damped enough to stop you feeling the steering, but just takes out some of the minor wobble you get, like when you go over wee bumps etc. The front seems quite light on steering, and I'm hoping this will just sort things on steering response
Matt
I'v heard that all mk3s do, and in my ignorance, I assumed the mk2 would too. However, it's a v.old mk2, so I'm going to check to see if things changed on the later ones
my G plate had the correct steering arm knuckle with the 3rd bolt hole, the B plate didnt.
simple swap though
My 1.3's got the bolt hole, fitted damper no probs
It would seem the later ones had the additional hole, since my g plate has one, but the old x doesn't. Anyone got one for sale?
