HID lights on polo, will the light pattern be ok?
hi,
i was thinking about getting HID lights for my car but was wondering will the light pattern be ok for the MOT?
anyone know if they will be ok?
thanks
  • Replies 28
  • Views 3.1k
I think the maximum is 6000. Correct me if I'm wrong. 8000 is too blue.
the numbers are the different colours, but sometimes when you put new bulbs in it will blind other drivers just wondering if they wil be ok?
Fitted HiD's to my car about a month ago.Had the MOT last week, the aim was a bit off but apart from that they were fine. If you fit them and then take them to a garage, they should be able to align them for a few quid. :)
Just make sure you put them in completely straight and not at an angle.
I've heard that if you get the h7r bulbs instead of just h7 they have a better beam pattern in reflectors, if you have projectors theres no need to worry ;)
ok cool,
I've got to buy the h4 hi and low beam hid lights for my car. but should be ok. £50 sound the right price?
The set i got off ebay was £37 , i was expecting it to be bad but took a chance.
I've looked at the beams and they look spot on , Couldnt fault it apart from a clunk when you flash full beam.
6k H4 set fitted into my 6n 16v
http://www.facebook.com/photo.php?fbid=480...33773.509299576
Not on the 6N2 because each bulb has it's own little compartment in the lens if that makes sense. You only need the reflector thing for the old school lights where the bulb is just bare in the cluster.
But yeah, projectors ftw.
From December 2011 it'll be illegal to retrofit HID's into cars that didn't have them fitted as standard.
Yeah and your point is?
av got 8k's on my white 6n2, look dope as, not too blue, 10k + would be
My point is that you could have the best beam pattern in the world but in 12 months time they'll be illegal. You're better off fitting relays in the wiring and fitting the brightest bulbs you can get they're loads better anyway.
Matt
Matt
so in 12 months time, everybody has to take there hids out to pass a mot, or take them out full stop else your gonna get pulled?
But if they're already fitted... :ninja:
Matt
At the least you'll have to take them out to pass the MOT but you will be breaking the law re-fitting them and driving around, and its not like they're difficult to spot. It's not like German plates where you can try and wing it by saying you'll swap them there and then either as they're not something you can swap at the side of the road, will probably be points/fine/MOT void.
Adam - From December 2011 it'll be illegal to retrofit HID's into cars that didn't have them fitted as standard
i.e OEM fitted when the car was built.
Matt
Meh.
What the hell? What fucking reasoning do they have behind this?
"How dare people with older cars attempt to see better at night" or somehting? I can see no logical reason why they would make it illegal to upgrade your headlights.
Because if not fitted properly, you get di*ks blinding you because they put the bulbs in wrong or something!
Its the people that mess it up for people like us!
Under this new law. It is technically legal to retrofit them, as long as there is a headlamp levelling system and a headlamp washer system, but to be fair all this will probably mean is you have to switch back to halogen for mot.
Also for a few months now it had been illigal to sell second hand hiss, as there is already a law in place that sates any retrofited bids must be brand new. This is good and bad. Good because it means that all he gear is up to scratch and that the price of new kits a are getting cheaper ( has anyone noticed the price crash in the last few months?). Bad be use now you can't by cheap as chips second hand ones.
But more to the point, if you have h4 bulbs, then us h4-4 telescopic bo-xenon kits. If you have h7 then only use. H7r in general, as they are a newer design and mostly of better quality.
I've got the telescopic h4 hi/los. i could easily carry a pair of h4s in the golvebox and swap them over on the side of the road. it would mean unplugging inline fuse and moving the 3pin plug from hid bulb to h4 bulb....
It's not a new law. It's never been legal to fit HIDs unless you fitted them as the OEM did using OEM parts.
It's a relatively new law, it came around or at least changed in 2010, google it
The only reason they are planning to enforce a rule against the use of these is because people fit them and do not align there light beams meaning oncoming traffic and other road users are blinded. If your lights are priperly aligned and used correctly then there will be no problems. As far as being pulled for them, regadless of uif they are HID or not - if there blinding pc plod he wont like it!
I have never failed an mot for using HID's and unless forced to I never will, but what I personally do is realign the light pattern correctly for any car that has them fitted, even if they seam fine.
Edited by dixynormous
I will repeat myself with some evidence. It's never been legal to fit HIDs unless you fitted them as the OEM did using OEM parts.
That's because the MOT can only check for alignment and pattern. They are not policemen, they do not uphold the law, they check what they told to check. Nothing more, nothing less.
Edited by yeha
Dude, read it again... SLOWLY your saying the same thing I am. Nobody is arguing the fact
