polo mk1 2 3 280/280 piper cam £75
brought a piper 280/280 cam of a friend i aint used it as i sold my car get some piks up.
£75 pick up only as i dont have time to post located in carshalton surrey thanks
  • Replies 15
  • Views 455
You will need to specify what cam it is in more detail as the mk1 engine is mechanical and the later mk2/3 hydraulic so surely the came would not fit mk1, 2 and 3?
ok sorry its for hydro heads
(bp300hy) (hd05) (505) there the numbers on the camshaft suited for 1.3.
280... pretty savage!
Pm'd
Would this fit a mk2 coupe s 1272? If it does would i need any mods to run it?
I dont think it will work on the coupe s as the enigine has a mechanical head.
if its got a hydrolic head should be fine (if your rocker cover has 3 bolts) better to have bike carbs or twin 40s and exhaust system
The rocker cover has 3 bolts but its a cam driven fuel pump with hydralic tappets? I will definatly have this if it will run! Does it come with a pulley?
No it's not. The coupe s has a hydro
Not all do ;)
Early spec's have mechanical heads remember.
M
you would have to change to a electric fuel pump ad the pump wont be a to go over the cam lobes. and no exrta 75pound for the pulley.
would this suit a gt pretty well? or is it just tooo lumpy, piston kissing? if not ill be taking it if you will post please :)
SOLD!!
