Removing Rear Wiper 6n2 Gti.
I am thinking about removing my rear wiper blade and just want to check I know what I'm doing.
You 'Simply' remove the blade from the outside, take off the plasic covering on the inside of the boot, take out the mechanism and put that plasic cover back on, job done?
Also what do you use to fill in the hole that will now be there?
Thanks, Alistair.
sounds about rite,if u mean the hole in the glass u can buy gromits for em i am sure someone on here will b able to direct u, also u can get these glass style gromits u glue in
Make sure you block your rear screen wash otherwise youll probally end up with a wet boot ;)
Yeah, just need to know the size and what options i have with the gromits :)
Ha oh yes, when i first bought my car it had fallen off and that happened to me :x
