Can i spray can paint my polo at home?
I've smashed up my polo and will be putting random coloured parts around the body, how easy is it to spray can a whole car a satin colour? what steps do i need to do? do i need to sand the whole car? thanks
  • Replies 8
  • Views 1.4k
The paintwork would need to be rubbed down , primed and then painted.
Shouldn't look to bad as long as you can get the car sheltered. You will also need to mask of everything you don't want to get paint on,
In fact, I am also planning on doing this, the paint work on my mk3 has faded considerably whilst it has been stud of the road.
M
what do you drive now max
Mk2 scirocco.
You not seen my thread?
M
Which panels? I recently sprayed a whole door and a wing with rattle cans, most people can't tell! Don't ruin it by painting your whole car satin.
The key is in the prepping. Take a long while over it, sand it down to a primer, fill any slight dents etc. I usually do 3 coats of primer (lightly sanding between each), 3 coats of paint (sand after first), then a couple of lacquer (if it needs to be done). Rub it down with 1200 grit then use some G3 compound and a machine polisher... if you haven't got them then a vigorous rub with auto glym paint renovator will bring out the shine, should come up lovely if done properly!
Hi, i need to paint, boot, bonnet, both bumpers, and rear 1/4s lol, tempted to just scrap it really :/
ok maybe not then.... :lol:
woh! save the polo!
firstly what kind of accident were you in? just interested :-)
What colour is it?
I'd try rattle canning it in the original colour. Or slap them on as they are and wait for someone breaking the same colour polo.
cant believe you could say you might just scrap it in such an easy sentence I'm heart broken!!!! :'(
